TURCK Q08 Proximity Sensors
By Miles Budimir | July 23, 2009
Minneapolis, MN – TURCK announces that the company’s rugged Q08 uprox®+ factor 1 sensor–designed to detect steel, stainless steel, copper, brass and aluminum at the same rated sensing distance–now offers an extended range of 8 mm. With no reduction factor, uprox+ factor 1 sensors save significant time and labor costs over standard ferrite core proximity sensors, which must be adjusted and reinstalled to detect different metal types. Along with its extended range, the Q08 sensor features a compact rectangular housing that makes it well suited for applications where mounting space is limited.
The Q08 sensor family comes equipped with internal shielding that effectively eliminates pre-damping, allowing users to employ the sensor’s full switching distance without hindrance–even when the device is mounted on metal surfaces. An IP 68 protection rating affords greater application flexibility, as the Q08 sensor can resist dust, debris and moisture ingress in challenging manufacturing environments. Two LEDs additionally provide clear visual indication of the sensor’s switching status.
TURCK
www.turck.us
Filed Under: Sensors (position + other), Test + measurement • test equipment
mti
MTI
moog
