    • On the Floor
When should you use dual guide rails?
By Danielle Collins | March 25, 2016
Linear guide rails and bearings offer high stiffness and good travel accuracy. And they can support not only downward, upward, and side loads, they can also withstand overhung, or moment loads. Of course, the larger the linear rail and bearing system, the more moment capacity it has, but the arrangement of the bearing raceways—face-to-face or back-to-back—also influences the amount of overhung load that it can support.
While the face-to-face design (also known as the “X” arrangement) provides equal load capacities in all directions, it results in a shorter moment arm along which overhung loads are applied, which reduces moment load capacity. The back-to-back arrangement (also known as the “O” arrangement) provides a larger moment arm and gives higher moment load capacities.
Linear Bearing Design Face-to-Face
The face-to-face raceway arrangement results in a shorter moment arm and lower moment capacities.
Image credit: Bosch Rexroth
Linear Bearing Design Back-to-Back
The back-to-back raceway arrangement produces a longer moment arm and higher moment capacities.
Even with the back-to-back arrangement, however, linear guides have a relatively short distance between the raceways (essentially equal to the width of the rail), which limits their ability to handle roll moments, which are caused by loads overhung in the Y direction. To counter this limitation, using two rails in parallel—with either one or two bearings on each rail—allows the roll moment to be resolved into forces on each bearing block. Since linear bearings have much higher capacity for forces than for moments (especially roll moments), bearing life can be significantly increased. Another benefit of using dual guide rails and allowing moments to be resolved into forces is that linear bearings generally deflect less under pure forces than under moment loads.
dual guide rails
When dual guide rails with one bearing each are used, no roll moments (Mr) are induced; only pitch (Mp) and yaw (My) moments.
Image credit: NSK Ltd.
dual guide rails
When dual guide rails with two bearings each are used, only downward (Fr) and side (Fs) forces are induced; no pitch, roll, or yaw moments.
Many linear actuator designs include two rails in parallel, with the drive mechanism—belt, screw, or linear motor—incorporated between the rails. While it’s not imperative that the drive be centered between the guide rails, doing so helps ensure even loading on all of the bearings, and reduces cogging, or uneven drive forces on each rail and bearing set. This arrangement also reduces the height of the actuator, making it relatively compact given the high load and moment capacity provided by the dual guide rails.
dual guide rails
Linear actuators with dual guide rails provide high roll moment capacity.
Recirculating bearings (bushings) that ride on round shafts are unable to handle roll moments. This is why most linear bushing applications require that two shafts be used in parallel.
Linear Motion Tips
Filed Under: Linear Motion Tips, Motion control • motor controls
Danielle Collins
    • On the Floor
