    • Subscribe!
Vacuum-tight connectors handle harsh environments
By rtraiger | June 2, 2022
Extending the capabilities of its field-proven M series, LEMO is introducing the new cutting-edge M series HY, a new model specifically designed for all applications requiring vacuum-tight connections in harsh environments. Its ultra-low leak rate, coupled with a wide operating temperature range, allows for unmatched performance in optical enclosures or high-altitude applications.
This new addition to the M series lineup provides customers with the highest density ratchet coupling connectors on the market where vacuum-tight integrations are required. The new LEMO M series Vacuum-Tight Connectors offer the most reliable, safe, rugged, and lightweight interconnect solutions for aerospace, automotive, defense, tactical communication, and UAV applications.
Filed Under: Connector Tips
Tagged With: lemo
Sager Electronics announces major expansion
Spring-loaded magnetic floating connectors
Connector and terminal products for gas and battery powered equipment
Harwin & MSA Components sign German distribution deal
    • Subscribe!
