WAGO Terminal Blocks Carry 100 kA SCCR
By Design World Staff | August 25, 2008
Germantown, WI – WAGO Corporation‚’s DIN-rail mount terminal blocks, ranging from the 280 Series to 285 Series POWER CAGE CLAMP‚®, now carry a 100 kA Short Circuit Current Rating (SCCR) when used with appropriate fuses. The SCCR originates from changes enacted by the National Electric Code and is represented as UL508A.
SCCR ensures proper documentation of the maximum short circuit current a component, assembly or equipment can safely withstand when protected by a specific overcurrent protective device. For instance, a control cabinet‚’s SCCR is the same as that of a component, in the cabinet‚’s electrical distribution path, with the lowest SCCR.
www.wago.us
Filed Under: Terminal blocks, ELECTRONICS • ELECTRICAL
