The D10 Expert™ Small Object Counter consists of a D10 Expert sensor paired with preconfigured PFVCA fiber optic arrays, creating a two-dimensional sensing field in which objects are readily detected when they break any point of the array. This unit eases alignment and object positioning. Consistent small object counting response times can be as fast as 150 ms.
The Dynamic Event Stretcher (DES) prevents double-counting translucent gel caps and similar small objects. Automatic Compensation allows the sensor to adapt the switching threshold to its environment in real time. Health Mode Alarm monitors the sensor’s performance and alerts operators about preventative maintenance.
Banner Engineering
www.bannerengineering.com
Filed Under: SENSORS, TEST & MEASUREMENT
