Being extremely well sealed, this rocker switch is particularly suited for demanding environments, especially on all-in-one joystick controls. Circular in shape (22 mm dia.) and with LED resistors embedded, it can be easily mounted and installed on a control lever.
The FNR series is ergonomically optimized and has excellent tactile effect. Whether it is mounted on the forward side of the joystick or on the lever, its ergonomically designed size and height means that the final user experience is more intuitive. Handling is comfortable and precise, even when used repeatedly.
Because of the vertical integration of all our production phases, this new rocker switch can be personalized for backlighting (five colors available), markings, extra sealing, flying leads output (type and length) and connectors.
APEM, Inc., 970 Park Center Drive, Vista, CA 92081, 760.598.2518, www.apem.com
You may also like:
Filed Under: Switches
