    • Subscribe!
BGA socket adapter constructed with high temperature FR-4 substrate
By atesmeh | November 25, 2014
Ironwood Electronics (Eagan, MN) released a new BGA socket adapter for 724 pin BGA, 1mm pitch, 35x35mm IC size. The BGA socket adapter consists of two modules (female socket module and male adapter module). The patented female socket module was built with machined pins epoxy over molded into an assembly that matches the male adapter module with similar construction. The SF-BGA724A-B-42F (female socket module) can be soldered to a mother board using standard soldering methods without warping that result in reliable connection to PCB. Other features include:
• Construction with a high-temperature FR-4 substrate.
• Lead and lead free solder ball type options.
• Passed environmental tests (MIL-STD) and qualified for various range of applications including automotive, military, communications, industrial, etc.
For more information on the BGA socket adapter, visit www.ironwoodelectronics.com.
    • Subscribe!
