The CPE solenoid valve from Festo Corporation has proven its long service
life and high performance with millions of installed units over many years.
The classic CPE valve now has something new to offer: aluminum manifolds
and M8 solenoid connections.
With its slim width, the CPE valve offers the highest flow rate of any
valve of its size. The valve’s compact size enables it to be installed
directly on the cylinders or on moving parts. These valves can withstand
the toughest operating conditions.
The CPE solenoid valve can be used as an individual valve or can be mounted
on a sturdy aluminum manifold — a convenient way to simplify an
installation.
Performance Highlights:
Space optimization — widths of 10, 14, and 18 mm on an aluminum
manifold rail
Flow rates of 350, 800, and 1,500 l/min
Economical operation with low power consumption of 1 or 1.5 watts
Wide pressure range of -9.9 … 10 bar for universal use
Switching times as low as 12 ms
Service Life Highlights:
Very long service life (100 million operating cycles)
Ultra low leakage rates
Maintenance free
Connection Technology
Wide choice of electrical connections
Aluminum manifolds in lengths of 2, 3, 4… 10 valve positions
Comprehensive rage of accessories
The aluminum manifold accepts all combinations of 5/2-way valves and
5/3-2way valves. The valve positions can be covered by a blanking plate
for future expansion. Integrated manual override, standard on CPE valves,
makes for easy commissioning.
Festo
www.festo.com
:Design World:
Filed Under: Valves
