Dorner’s 3200 Receives Cleanroom Certification
By Editor | November 14, 2013
Dorner’s 3200 Precision Move low profile belt conveyor platform has received the Ultraclean Products Approval Laboratory certification for use in ISO Standard 14644-1 Class 5, and Federal Standard 209 Class 100 rated cleanrooms. This means that 3200 Precision Move conveyors will not contribute to the contamination of cleanrooms conforming to those standards.
Dorner’s-3200-Receives-Cleanroom-Certification
Cleanrooms and other controlled environments provide for the management of airborne particulate contamination to appropriate levels for accomplishing contamination-sensitive activities. Industries that regularly use cleanrooms in their manufacturing processes include aerospace, pharmaceuticals, medical and healthcare.
The 3200 Precision Move is ideally suited to operate in cleanroom environments requiring automation with accurate movement over distance and time. The offering has the latest advancements in timing belting and drive technology. What Precision Move gives to specific applications such as machine integration, robotic pick-n-place, precision indexing, accurate part positioning, timed conveying, vision inspection and sheet or wide part handling is a new level of functionality and capability to the proven platform of the 3200 Series. Flexibility is often a requirement for cleanroom equipment; the 3200 Precision Move’s low profile allows it to fit in extremely tight places, giving customers flexibility to adjust to changing cleanroom applications. Additionally, since the 3200 Precision Move also comes in virtually any length up to 50 feet, the conveyor becomes an integral component of any larger cleanroom processing or manufacturing system.
The 3200 Precision Move is ideal for a variety of medium to large part transfers, part accumulation, precision part movement, automated and manual assembly applications. Features of the 3200 Precision Move include:
• Flat belt end drive, cleated belt end drive
• 100 Indexes per minute rated
• Conveyor mechanical accuracy of +/- .01”
• Mounting System for direct mounts or pallet fixtures
• Widths up to 18”
• Lengths up to 50’
• Loads up to 750 pounds
The Ultraclean Products Approval Laboratory certification is a leading national test center for contamination control engineering. Some of the testing and certification services include a variety of cleanroom equipment such as benches, cabinets, fume hoods, material handling systems, and vertical and horizontal flow cleanrooms.
Dorners
www.dornerconveyors.com
Filed Under: Conveyors, LINEAR MOTION, MOTION CONTROL, Motion control • motor controls
Tagged With: dorner
