Dynatect introduces the ChemTank Cover, a corrosion-resistant chemical tank cover developed in response to the demand for convenient and space-saving options. The cover is designed to accommodate a wide range of tank applications including chemical and surface finishing, anodizing, etching, plating, cleaning and more. The cover system helps reduce heat-loss and evaporation. Its roll-up design offers easy manual or drill-drive operation.
To maximize chemical and temperature compatibility, Dynatect’s ChemTank Cover includes a PVDF-coated PVC shade and compatible hardware. A stainless steel wiper removes the any condensation from the cover as it is retracted. The ChemTank Cover is for tank opening widths from 24 to 80-in. The roll-up feature can be applied to tanks up to 60 feet long which often can’t be addressed by fixed plate alternatives.
To evaluate their return on investment for applying a ChemTank Cover, facility managers should consider if they are losing money due to evaporation or energy efficiency due to continuously heating open tanks. Covers are also a logical approach to improving the work environment and air quality. Considering ergonomics and the necessity to contain hazardous fumes, ChemTank Cover may appeal as a regulatory countermeasure. With a roll-up design that’s easily opened and closed, operators need not struggle with manually lifting and adjusting panels, which also pose a splash risk. The roll-up design also eliminates the challenge of where to store manual cover panels. The cover efficiently travels at about 1-ft per rotation.
Dynatect designs and manufactures a wide variety of industrial roll-up covers for use in manufacturing, foundry, processing, and plating facilities. The ChemTank Cover has already been engineered for maximum compatibility with both new and retrofit installations. While there can still be applications outside the scope of the ChemTank Cover, Dynatect continues to offer the Steelflex metal roll-up cover as an alternative.
Dynatect
www.dynatect.com
