Ethernet switch module offers twelve 10/100/1000 Mbps copper twisted pair ports
By atesmeh | December 20, 2013
[[{“fid”:”35727″,”view_mode”:”default”,”fields”:{“field_file_image_alt_text[und][0][value]”:””,”field_file_image_title_text[und][0][value]”:””},”type”:”media”,”attributes”:{“height”:300,”width”:300,”style”:”float: right; margin: 5px;”,”class”:”media-element file-default”}}]]Diamond Systems unveiled Epsilon-12G2. The rugged, managed Layer 2+ Ethernet switch module offers twelve 10/100/1000 Mbps copper twisted pair ports and two small form factor pluggable (SFP) sockets in a compact COM Express form factor.
The new standalone switch does not require any host computer interface. A 480 MHz MIPS processor embedded directly into the switch manages all switch functions. The processor is accessed via an in-band web interface over one of the Ethernet ports or via an out-of-band command-line interface over an RS-232 serial port. The integrated web interface provides an intuitive GUI for configuring and managing all switch functionality.
On-board memory holds dual application images, boot code, MAC addresses and other parameters, and can also be used for program execution.
Designed for use in rugged applications including industrial, on-vehicle and military environments, Epsilon-12G2 operates over an extended temperature range of -40°C to +85°C.  All I/O connectors are latching, providing enhanced reliability over the RJ-45 connectors used in commercial Ethernet switches. A 50% thicker PCB provides better protection against vibration in vehicle environments. The +5 V to +40 V wide range DC/DC power supply is compatible with all common vehicle and industrial power sources.
The switch’s dual SFP socket interfaces to 1 G fiber Ethernet networks. One port can operate at an enhanced 2.5 G to support efficient stacking of two switches together for a combined total of 26 ports.
Epsilon-12G2 comes with all the required firmware preconfigured, enabling immediate operation without any development effort.
Technical specifications:
  • 12 10/100/1000 Mbps Ethernet ports
  • 1 1 G and 1 2.5 G SFP socket
  • Built-in microcontroller for configuration and management
  • RS-232 serial interface for out-of-band management interface
  • +5 V to +40 V wide range DC/DC power supply
  • COM Express form factor (95 mm x 125 mm)
  • -40°C to +85°C operating temperature
 Advanced Ethernet features:
  • Dual leaky bucket policers with remarking and statistics
  • Jumbo frame support at all speeds
  • 8K MAC addresses and 4K VLANs (IEEE 802.1Q)
  • 8K IPv4 and IPv6 multicast group support
  • Flexible link aggregation support based on Layer-2 through Layer-4 information (IEEE 802.3ad)
  • Multicast and broadcast storm control, as well as flooding control
  • Rapid Spanning Tree protocol (RSTP) and MSTP
  • 8 priorities and 8 QoS queues per port with scheduling
  • Shaping/policing per queue and per port
  • Multiple protocol support: IEEE 802.1d, IEEE 802.1w, IEEE 802.1s, IEEE 802.1X
Pricing and availability
The Epsilon-12G2 14-Port Gigabit Managed Ethernet Switch is shipping now. Single unit pricing starts at US $800. A separate cable kit is available: CK-EPS12G2.
For more information, call 800-367-2104, visit http://www.diamondsystems.com/products/epsilon12g2
