Gigabit Ethernet PoE cards
By Editor | April 8, 2013
Two PCIE Gigabit Ethernet Power over Ethernet (PoE) Cards, the PCIE-1672PC and 1674PC, are two and four-port cards that work in industrial PCs such as the UNO-3xxx series. With up to 15.4 watts of power per port, the two cards can power IEEE802.3af compliant devices without the need for additional power wiring. Each card has an integrated network processor (NPU) enabling the industrial PCs’ CPU to perform its other tasks by offloading the network traffic management to the NPU.
PCIE1674PC_opt
Speed is 10/100/1000 Mbps per port by Intel i350 controllers. The cards also have IEEE Gigabit 802.3af with power isolation, and IEEE 1588 PTP protocol. They support 12 Vdc AT/ATX input power, up to 15.4 watts at 48 Vdc per PoE port. Power requirement is max 0.6 A at 12 V from external power plug via 4-pin power connector.
Advantech Corporation
www.advantech.com/ea
Filed Under: CONNECTIVITY • fieldbuses • networks • gateways, Connectors (electrical) • crimp technologies, PCs
Tagged With: advantech
