Heilind Electronics, a leading international distributor of electronic components and an authorized distributor for Hirose, is now stocking the manufacturer’s D.FL75 Series 75 ohm coaxial connector.
The D.FL75 Series supports the 12G-SDI and SMPTE ST 2081-1 video standards, improving board design freedom while reducing design time for internal wiring. A Hirose BNC(75) – D.FL micro coax adapter may be designed into the product panel, attaching modularly to a thin, D.FL micro-coax cable internally, in turn mating to a small, flexibly placed D.FL75 receptacle on the internal PCB. High integrity signals are now routed through shielded coax, with better performance, smaller PCB space requirements (the D.FL receptacle is just 4x4mm, and ultimate flexibility in panel connector placement with respect to internal PCB designs.
A key feature of the D.FL75 Series is the resulting independence of product panel and internal board design and assembly. This allows designs to be completely independent of each other. Separating the manufacturing and assembly sites allows flexibility in both design and manufacturing.
The D.FL75 Series is ideal for the computer, datacom, telecommunications, medical and industrial manufacturing markets. For more information about the Hirose D.FL75 Series, visit heilind.com.
You may also like:
