Improve Productivity with CLN Series LED Work Lights from PATLITE
By Editor | April 17, 2013
Patlite introduces CLN Series LED Work Lights. These IP66G, IP67G and IP69K-rated work lights deliver brilliant 820 lx lighting (CD model), and can do so at 70 percent of the original brightness for up to 60,000 hours even when subjected to dust, water, oil, chemicals and machine coolants. At just 22.2 mm (0.87 in.) wide with a 180 degree angle tilt adjustment and a 120 degree rotating adjustment (PT model), the CLN series is also  one of industry’s thinnest LED work lights with flexibility to be mounted virtually anywhere. The result is improved productivity and reduced maintenance time and costs.
LED Work Lights
CLN series LED work lights provide warm white light with natural light distribution to illuminate a wider work area, or virtual midday sunlight color for detailed and fine work, and illuminate a wider work area than many similar models. They attach virtually anywhere with a stainless steel angle bracket, including the floor, wall and ceiling, and provide rotation angles that maximize operational flexibility.  An Explosion Safe version for Zone 2, Zone 22 (Ex nA IIC T4 Gc,  Ex tc IIIC T135°C Dc IP65) is available.
PATLITE
www.patlite.com
Filed Under: Lights • signal lamps • indicators, ELECTRONICS • ELECTRICAL
Tagged With: Patlite
