Koford Engineering now offers 36-mm high-performance motor
By Heather Hall | March 18, 2024
Koford Engineering LLC has introduced a 36 mm diameter x 43.6 mm long, high power density four pole slotless hall sensor brushlessmotor.  The motor produces an output of 260 watts at 6,753 rpm, weighs 198 g, and has a peak efficiency of 87%. Typical applications include surgical power tools or aerospace applications. The motor can withstand steam autoclave in a sealed housing or using an autoclave bag. The motor has a hardened stainless steel shaft and TFE lead wires. Modifications such as flats on the shaft or special shaft lengths are possible. Optical encoders and gearboxes are offered. Matching high-efficiency drives are available.
www.koford.com
Filed Under: Motors • dc
Tagged With: koford, kofordengineering
