(Torrance, CA)- LEDtronics® announces the release of its new DC-to-DC Dimmer for LED Lighting Products, supporting 5VoltsDC to 40VoltsDC applications–up to 2Amps or 24Watts–LEDtronics Part Number LED-DIMMER-001. The LED Dimmer makes it possible to dim all 5VoltsDC to 40VoltsDC LED products such as LED strip lights, LED bulbs and LED floodlights.
Since LEDs draw much less current than traditional incandescent bulbs one had to buy a special high-end electronic dimmer to control the desired light levels for their LED lighting application. The DC-to-DC LED Dimmer is ideal to use for all your 12VoltsDC LED products, mix-and-match LED light strips and LED bulbs, maximum load per DC-to-DC Dimmer is 24Watts. The LED Dimmer will enhance your architectural low power high-benefit lighting designs. Here’s an extra advantage in using an LED dimmer: by lowering the current to the LED, you extend the life of the LED.
http://www.ledtronics.com/pages/pr_111907.htm
: Design World :
Filed Under: Lights • signal lamps • indicators
