Woodstock, CT – The Linemaster Hercules Potentiometer foot switch was designed for use with variable speed motor drives and is available in select 2-Watt linear values (customer to specify the maximum resistance required). The Hercules Potentiometer has a robust cast iron housing and providing long life in heavy duty applications. Most models are offered with a cast aluminum shield in sizes designed to accommodate the standard size shoe or up to a large work boot with metatarsal guard. The Hercules Potentiometer switches are offered in momentary (spring return) action with up to (3) SPDT auxiliary snap switches. All models are NEMA Types 2, 4 & 13 and meet the requirements of IP56 specifications.
These foot switches can be used on a variety of equipment such as material handling equipment, welding equipment, metal working machines, drill presses and potters wheels. Custom models are available upon request and options can include a special dual cover casting for twin models, private labeling, custom paint finishes, and cordsets built to the customer’s specifications. www.linemaster.com/lp/e-0903-002
Linemaster Switch Corp.
www.linemaster.com
Filed Under: Potentiometers, Material handling • converting, Switches, ELECTRONICS • ELECTRICAL
THE FOOT 10 K OMNIOS ?
[email protected]
