Low Pressure Transducers from Gems
By Patrick Curran | July 17, 2009
Plainville CT – Gems® Sensors & Controls™ announces the launch of the new 3300 series pressure transducer. The 3300 series transducer is designed for low pressure applications that demand small size and low cost along with high accuracy and stability. The 3300 Series pressure transducer is well suited to applications such as chemical sterilizers, autoclaves, pneumatics, HVAC&R, pumps & compressors.
The 3300 pressure transducer is the newest addition to the highly successful 3100 and 3200 series transducers, bringing a versatile low pressure capability to the product line and opening up a host of new applications across a number of different industries. All stainless steel wetted parts and all welded construction make the unit compatible with harsh chemicals and environments. In addition, the unique temperature compensation at source technology delivers outstanding temperature stability.
The 3300 series is available in pressure ranges from 15 to 250 psi and is capable of operating over a temperature range of -40°F to 257°F. Available in voltage, current, and ratiometric outputs, with a wide selection of connectors, pressure fittings and mating connectors makes the 3300 suitable for many applications without modification.
Gems Sensors & Controls
www.GemsSensors.com
Filed Under: Sensors (pressure), Test + measurement • test equipment
mti
MTI
moog
