    • On the Floor
Mechanical Hygrostat
By Design World Staff | October 3, 2008
Omega’s new series of Mechanical Hygrostat is designed to control the relative air humidity inside of enclosures.
When connected to an enclosure heater, (de-humidifier), it will turn the heater on at the set humidity level in order to raise the dew point. This helps prevent damage and malfunction of electronic components caused by condensation and corrosion. The MFR012 has a high switching capacity and is DIN rail mountable. This CE compliant product can also be used to control cooling fans, warning lights or other devices.
www.omega.com
Filed Under: Cabinets • enclosures • control panels • DIN rail, TEST & MEASUREMENT
  • Toyota goes all-in on humanoid robots
  • Mobile robotics moves to the textile industry
  • Finally, hard data on humanoid robot cost in the factory
    • On the Floor
