New 3200 MHz VCO From Crystek Corporation
By WDD Staff | November 4, 2014
Crystek’s CVCO55CC-3200-3200VCO (Voltage Controlled Oscillator) operates at 3200 MHz with a control voltage range of 0.5V~4.5V. This VCO features a typical phase noise of -112 dBc/Hz @ 10KHz offset and has excellent linearity. Output power is typically +5 dBm. Engineered and manufactured in the USA, the model CVCO55CC-3200-3200VCO is packaged in the industry-standard 0.5-in. x 0.5-in. SMD package. Input voltage is 8V, with a typ. current consumption of 30 mA. Pulling and Pushing are minimized to 3.0 MHz and 0.1 MHz/V, respectively. Second harmonic suppression is -12dBc typical.
The datasheet for this CCSO is available from this link: http://www.crystek.com/home/vco/cvcodetail.aspx?pn=CVCO55CC-3200-3200
