Moorpark, CA ‚– Kavlico introduces the Models P4055/P4056 OEM Pressure Sensors. These devices have a piezo-resistive sense element and the P4050 is available in pressure ranges of 0-3 through 0-300 psi gage, sealed gage, and absolute while the P4056 is available in measurement ranges of 0 – 200 mBar through 20 Bar. The rugged, brass sensors are compatible with many types of liquid and gaseous media.
Small in size (40 grams max.), the P4055/P4056 have a built-in Metri-Pack 150 electrical connector. Operating on 5 Vdc, the sensors provide a 0.5 to 4.5 Vdc output proportional to pressure. Pressure port options include NPT, G 1/4, M10, and M12. The temperature compensated sensors exhibit exception EMI/RFI performance and can tolerate high vibration environments. The sensors have a total error band is ‚±2% over -20 to +85 ‚ºC while the having a full operating temperature range is -40 to +125‚ºC.
The P4055/P4056 are RoHS compliant and carry CE certification. Customized pressure ranges are available for high volume applications.
Filed Under: Sensors (pressure), TEST & MEASUREMENT
