At just 1.38 in. long, the ELS-1150 is upgraded with a microprocessor board design to provide a wide range of capabilities including sinking and sourcing and time delay outputs.
The strong fused glass prism eliminates leaks and can handle extreme temperature and pressure applications up to 2500 psi. Available in FM and EP versions with wide voltage ranges and temperature ranges up to 125 C (ELS-1150XP), and in nickel-plated carbon steel or stainless steel.
Gems Sensors & Controls
www.GemsSensors.com
Filed Under: Sensors (position + other), Test + measurement • test equipment
