  • Articles
  • 3D CAD Models
    • 2020 Winners
    • 2019 Winners
    • 2020 LEAP Awards
    • DIGITAL ISSUES
      • EE World Digital Issues
    • 2020 LEAP Awards
    • Motion Design Guide Library
    • Suppliers
  • COVID-19
Opto 22 releases two more groov EPIC I/O modules for 2019
By Mike Santora | December 23, 2019
Opto-22-2333-GRV-ITM-CombineOpto-22-groov-epic-i/o-moduleRight after the recent release of three specialty input/output modules for the groov EPIC platform, Opto 22 has announced two more modules to close out the year. For system integrators and engineers, the new I/O modules provide more options for bringing field bus networks into groov EPIC, as well as meeting requirements for temperature control applications with high I/O count.
GRV-CCANI-2 (serial communication, 2 channels, CAN 2.0B, channel-to-channel isolation) is the first module in the groov EPIC platform to provide hardware support for an industrial field bus. This new module enables existing CAN networks to be brought into IIoT applications using groov EPIC’s fluid IT/OT connectivity tools, like Ignition Edge, Node-RED, and MQTT. groov EPIC also supports integrating CAN data into control applications using IEC 61131-3 languages, and enables mobile visualization of CAN data using groov View. Up to 8 CAN buses per processor at network speeds up to 1 Mbps are supported.
GRV-ITM-12 (analog input, 12 channels, thermocouple or millivolt) provides a high-density, low-cost temperature sensing option with two isolated zones and 6 channels per zone. Each channel is software configurable to one of seven millivolt ranges or eight thermocouple types (Type B, E, J, K, N, R, S, T). GRV-ITM-12 is accurate to 0.1% of the configured range over 20-bit resolution for V/mV sensing, with accuracy ranging from 2.0-5.0 °C for thermocouple sensing.
Features:
  • Touch-sensitive pad triggering module information display on the groov EPICprocessor
  • Removable top-mounted connector with single, captive retentionscrew
  • Spring-clamp field wiring terminals
  • Hot-swappable for installation and removal without turning off or stopping thesystem
  • UL Hazardous Locations approved and ATEXcompliant
  • Wide operating temperature range of –20 to +70°C
  • Individually factory tested twice and calibrated beforeshipment
  • Guaranteed for life (GRV-CCANI-2 for 30months)
Opto 22
www.opto22.com
MOTION DESIGN GUIDES
  • Configuration Management: Configuration Integrity IS A Core Driver for Business Success
  • How to Choose a Linear Actuator
  • Create your perfect machine with Advanced Engineering
  • How a ME/EE turned passion for design into his own bike company
  • Everyone Can Save on Cable Costs. Here’s How
  • How and Why You Should Use a Wave Spring for Bearing Preload
Tweets by @DesignWorld
  • Articles
  • 3D CAD Models
    • 2020 Winners
    • 2019 Winners
    • 2020 LEAP Awards
    • DIGITAL ISSUES
    • 2020 LEAP Awards
    • Suppliers
  • COVID-19
