Patlite NE Series visual and audible-visual signaling beacons from AutomationDirect
By Mike Santora | November 3, 2023
Patlite-ne-seriesAutomationDirect has added Patlite NE series visual and audible-visual signaling beacons to their portfolio of industrial signaling devices. These signaling devices are offered as visual-only beacons or as combination devices with a buzzer or selectable tone alarm (8 different tones) and signal beacon.
Mono-color beacons are available in red, yellow, green, blue, or clear models. Multi-color versions support 7 selectable colors allowing users to signal numerous different equipment conditions with one device.
Several connection types are available including screwless terminal block, M12 quick-disconnect, or pigtail connections, and select models support IO-Link for simplified wiring and remote configuration.
The Patlite NE series visual and audible-visual signaling beacons are rugged devices with an IP65, IP67, or IP69k protection rating.
AutomationDirect
www.automationdirect.com/signal-devices
Filed Under: Lights • signal lamps • indicators
Tagged With: automationdirect
