ROLEC conFORM EMI/RFI Shielded Enclosures Now In 14 Sizes
By Frank Tobe | June 23, 2017
ROLEC conFORM enclosures – which offer built-in EMI/RFI shielding without the need for expensive gaskets – are now available in 14 sizes (3.11” x 3.30” x 1.73” to 10.55” x 6.61” x 3.93”).
These tough diecast aluminum enclosures are designed for heavy duty industrial applications where EMI/RFI shielding is critical. They are ideal for electronics requiring regular maintenance: the lid can be removed and replaced without having to worry about damaging a conductive gasket.
ROLEC-conFORM-EnclosureROLEC conFORM’s integrated EMI/RFI shielding system uses uncoated teeth in the base and a contact rail in the lid to guarantee permanent metal-to-metal contact. Its high shielding from radiation interference has been tested by the University of Hanover.
Separate sealing and contact levels ensure the enclosures are able to offer IP 66 (IP 67 optional) ingress protection without compromising the EMI/RFI shielding.
The enclosures’ screw channels are outside the interior, maximising space for components. Inside, threaded screw bosses enable PCBs, mounting plates and terminal rails to be installed.
ROLEC conFORM is available in pebble gray (RAL 7032) as standard. Custom colors and a corrosion protection coating (RAL 5009) are also available. Prices for conFORM start at $37.
Accessories include external lid hinges, internal lid supports, external mounting brackets, a mounting kit, supporting rail and mounting plate.
ROLEC also offers a wide range of customization services including CNC machining, printing or engraving/laser engraving of logos and legends, membrane keypads and assembly.
ROLEC Enclosures, Inc.
www.rolec-usa.com
Filed Under: Cabinets • enclosures • control panels • DIN rail, Flanges • supports • mounts • brackets • hinges
Tagged With: rolec
