Flush-mount pushbutton features shallow mounting depth, stylish design
By Lee Teschler | November 24, 2021
The MSS Metal Line Switch is a flush-mount pushbutton with a very shallow mounting depth and stylish design. Sporting a multi-color side-ring illumination, the MSS provides the user with visual feedback from the side in addition to the front. The greater coverage allows for lateral status indication, which may be especially desired from a distance. Non-illuminated versions are also designed to provide visual indication with a colored bezel.
The MSS switching technology is extremely precise and is designed for applications where some degree of pressure is required to trigger the switching function. Not too little and not too much: Capacitive schurtertechnology triggers switching with only a touch, while mechanical technology has moving parts that can wear over time. The moving parts can also be subject to ingress. The MSS requires a light pressure of 1-3 N on the surface to provide just the right amount of touch to prevent unintentional switching. It has an IP rating of IP67 and a lifetime rating of >20 million actuations. Whether used in a home doorbell, or medical product, a laboratory device, or industrial equipment, the compact switch offers eight different bezel housing colors and a spectrum of RGB illumination colors for a host of customized options. Size offerings are 19, 22, and 30 mm diameter. In addition, with a slim mounting depth of only 8 mm, this switch is highly versatile for a variety of applications including those where depth is limited such as door jams and densely packed enclosures.
Switching voltage and current is max 60 Vdc and 100 mA. Operating temperature range is -40 to 85°C. The switching function is momentary (MO) or latching (LA). Highly robust for the demanding applications, the MSS actuator is stainless steel with an impact resistance rating of IK06.
Pricing starts at $22.00/piece in 100-piece quantities. Packaging is 10 pieces in a box and includes the nuts in a bag.
SCHURTER Inc., 447 Aviation Blvd., Santa Rosa, CA 95403,(800) 848-2600, [email protected], www.schurter.com.
You may also like:
  • PCB mills
  • Did you foresee Facebook?
  • 9-11 truthers
    The WTC collapse after two decades
  • scilab
    The top ten free engineering math software packages
  • electrocaloric cooling
    Keeping cool with capacitors
Filed Under: TECHNOLOGIES + PRODUCTS, Switches
Tagged With: schurterinc
PX AND PA Series foot switches
The fundamentals of electromechanical on/off switches
HoverTap Lift from NZ Technologies takes elevator call buttons to new highs
cui devices
Tactile switches target consumer electronics, office equipment, and industrial apps
