Minneapolis, MN – TURCK announces that the company’s line of BIM-UNR magnetic cylinder position sensors – designed to mount within C-groove cylinders with no accessories required – has been expanded to include sensors with NPN outputs.
BIM-UNR sensors are also now enhanced with a combination mounting screw that grants users the flexibility of choosing a 3/16″ (1.3 mm) Allen wrench or a flat-bladed screwdriver for sensor installation. Sensors can be securely mounted with a simple quarter-turn of the mounting screw, which is located in close proximity to the cable exit. This design ensures the sensors remain firmly fastened, even if a cable is pulled.
TURCK
www.turck.us
Filed Under: Sensors (position + other), Test + measurement • test equipment
