Two-hand control relay for use with mechanical push button applications
By Heather Hall | May 24, 2021
Norstat now offers a two-hand control relay specifically designed for use with mechanical push buttons in two-hand applications.
The HR-2007 relay is a safety category 4, two-hand control relay designed specifically for dangerous work processes such as punching or pressing. The HR-2007’s simple design and slim 22.5-mm housing allows for fast and easy installation via user friendly connections and gives verification of the operation of both switches within 0.5 sec.
The HR-2700 has internal short-circuit monitoring and status/fault indication LEDs for displaying the status of the internal relays and outputs and for power of channel’s 1 and 2, thereby reducing troubleshooting time. Available voltages are 230 Vac and 24 V ac/dc. The HR-2007 carries a protection rating of IP 40 for housing and IP 20 for terminal block and can operate in temperatures ranging from -25° C to +55° C.
Norstat
www.norstat.com
You may also like:
  • What’s the difference between NEMA and IEC motor starters?
  • Machine Monitoring & Energy Efficiency
  • IDEC
    Eight-port unmanaged ethernet switch supports QoS, IGMP snooping, broadcast storm…
  • R&D&$
    No worries: The internet would have arrived without Arpanet
  • allied siemens
    Modular solutions for industrial control panel design
  • 3D printing in the Desert
Filed Under: Relays
Tagged With: norstat
CIT
Automotive relays handle up to 80 A
https://www.te.com/usa-en/home.html
MIL-SPEC electromechanical relays from TE Connectivity
carlo gavazzi
Slim electromechanical plug-in relays and sockets sport screw and push-in terminals
ProSense Timer Relays from AutomationDirect
