connectBlue launched the Ethernet Port Adapter RWE251s which features Wireless LAN (WLAN) dual-band functionality and an omnidirectional external stub antenna. These features give the RWE251s a versatile use for both the 2.4GHz and 5GHz ISM bands as well as the possibility to freely select where to position the Ethernet Port Adapter.
Based on WLAN IEEE 802.11 a, b, g, n (also commonly referred to as Wi-Fi), the new Rugged WLAN Ethernet Port Adapter RWE251s from connectBlue is well-suited for industrial and medical applications where the Ethernet cable needs to be replaced with a robust wireless connection. The ready-to-use RWE251s optimizes the installation process as well as lowers the installation costs in demanding applications.
Dual-band support makes it easier to identify interference free channels and connect to networks that utilize both the WLAN 2.4 and the 5GHz radio bands and thereby coexistence between wireless technologies is facilitated.
The 11cm external stub antenna with RPSMA connector is omnidirectional and thus you do not need to align the units for optimal wireless connectivity. It is also possible to place the RWE251s inside and the stub antenna outside a metal cabinet giving maximum systems indesign possibilities.
The RWE251s offers the user seamless roaming and redundancy, high data throughput and a robust connection to the infrastructure. The product is IP65-classed and can operate in the extended temperature range of -30 to +65ºC.
Configuration of the device is simple and intuitive thanks to the SMART configuration mode and the availability of a web browser configuration tool. The RWE251s supports WEP64, WEP128, WPA-PSK, WPA2-PSK, TKIP, CCMP (AES), LEAP, PEAP and is radio type approved for US (FCC), Europe (ETSI R&TTE) and Canada (IC RSS). Further, the RWE251s is configurable to optimize for Profinet.
connectBlue
www.connectblue.com
Filed Under: Ethernet — cables • hubs • switches, Wireless devices
