  • Articles
  • 3D CAD Models
    • 2020 Winners
    • 2019 Winners
    • DIGITAL ISSUES
      • EE World Digital Issues
    • Motion Design Guide Library
    • Suppliers
  • COVID-19
EXAIR’s Heavy Duty Dry Vac vacuums more material in less time
By Kelsey Zebrowski | May 26, 2020
EXAIR’s Heavy Duty Dry Vac has been engineered to vacuum more dry materials in less time with less wear. Designed for tough industrial environments, the hardened alloy construction resists premature wear while the increased power handles difficult jobs and harsh conditions. And, the quiet operation makes it suitable for a wide variety of applications including the clean up of abrasive materials like steel shot, garnet, metal chips and sand while also useful for general purpose applications like vacuuming floors, machines, work stations, industrial machinery and equipment.
Electrically operated vacuums have motors and impellers that clog and wear out quickly. There’s also a potential shock hazard when electric vacs are used in standing liquids. The Heavy Duty Dry Vac is compressed air powered which eliminates the shock hazard. It has no moving parts to wear out or break, to assure long life. It is quiet with a sound level that is half that of electric vacs.
The Heavy Duty Dry Vac’s lever lock drum lid fits any thirty, fifty five or 110 gallon open top drum. Moving it from one drum to another can be done quickly, making it easy to keep different materials separate for recycling. All materials are vacuumed directly into the drum, eliminating the heavy lifting that is common with electrically powered vacuums. To prevent material contamination, a poly drum liner can be inserted into the drum.
For more information, vist exair.com.
You may also like:
  • No-drip spray nozzles from EXAIR sanitize, clean, and cool while…
  • EXAIR’s High Lift Drum Vac uses compressed air to move…
  • Dual 316SS Cabinet Coolers with digital control resist heat and…
  • Filter out chips with EXAIR’s Chip Trapper
  • EXAIR’s single point ionizer for spot neutralization
MOTION DESIGN GUIDES
  • Drilling rig OEM benefits from a PLC with edge computing technology: IIoT case study
  • The industry shift to smart electromechanical actuators
  • Commemorating a great entrepreneurial personality – Oskar Lapp at 100 – A pioneer for the future
  • SE motor – uncompromised motion performance
  • With virtual commissioning, commissioning time and prototype waste is reduced
  • Master Bond Supreme 10HT High strength, NASA low outgassing approved epoxy
Tweets by @DesignWorld
  • Articles
  • 3D CAD Models
    • 2020 Winners
    • 2019 Winners
    • DIGITAL ISSUES
    • Suppliers
  • COVID-19
