FUTEK Advanced Sensor Technology, Inc. (FUTEK) is announces a new addition to their USB Sensor Solutions Line. With 10 models to choose from, FUTEK’s In-Line Load Cells (LCM series) are now available with USB capabilities. These Load Cells have been built for endurance, off-center loading, press and in-line applications for both tension and compression measurements. Due to their robust construction, these models can withstand a capacity range of 25 lbs. to 700,000 lbs. Adding the USB Solution to the In-Line Load Cell line, gives users all the benefits of a quick plug & play system. The USB application simplifies the retention and computation of all data received via In-Line Load Cells by eliminating the need for amplifiers, filters, and multimeters. Thus, data logging and live graphing are readily available to the user the instant the measurement is taken.
These Load Cells are manufactured at FUTEK’s state of the art facility in Irvine, California (USA). The LCM Series includes:
LCM200
• Smallest size In Line Load Cell (LCM) Series
• Is Temperature Compensated 60° – 250°F by default
LCM300
• Capacity 25 lbs – 1,000 lbs
• Both Metric and English Threads Available
LCM325
• Capacity 2,000 lbs and 3,000 lbs
• Nonlinearity 0.5% Rated Output
LCM350
• Capacity 4,000 lbs and 5,000 lbs
LCM375
• Capacity 7,500 lbs and 10,000 lbs
LCM400
• 2,500 lbs capacity
• Microtech Connector Version
LCM500
• 2,000 lbs and 5,000 lbs Capacities
• Nonlinearity 0.2% Rated Output
• Availalle in Both Metric and English Threads
LCM525
• 10,000 lbs and 20,000 lbs Capacities
• Available in Both Metric and English Threads
LCM550
• 50,000 lbs Capacity
LCM675
• 700,000 lbs Capacity
• Nonlinearity 0.25% Rated Output
• Optional shackles available for mounting/installation
www.futek.com
Filed Under: Sensors (position + other), Test + measurement • test equipment
LCM300 – Is it possible to read load cell data without the included application? We have logging software we would need to reprogram to be able to work with these devices ( which we can do in house). What driver is required?
