SMART-PANEL enclosures are designed for intelligent building control and monitoring in a wide range of industrial, commercial and residential applications. They include IoT/IIoT, building services systems, electrical installations, wireless communications, measuring and control, security and access control, smart home, medical and laboratory technology.
Installation is swift and easy because SMART-PANEL’s top simply snaps into place: There are no visible fixing screws. It can be re-opened using a set of push-in opening tools (accessory). The large, recessed top can accommodate LEDs, displays or a membrane keypad. A touchscreen can also be fitted.
The bottom section fits standard flush-mounted/cavity wall boxes (maximum opening 2.4 in) and larger international installation boxes (up to 5.9-in high and 2.4-in wide). Electronic components are mounted in the top. A snap-in hardboard plate (accessory) protects the underlying electronics from the risk of damage during installation and maintenance.
SMART-PANEL is 0.84-in deep and available in two plan sizes: 3.30×3.30 in and 6.10×3.30 in. The enclosures are molded from tough and UV-stable ASA+PC-FR (UL 94 V-0) with a highly polished bottom section and a fine-textured top. The standard color is traffic white (RAL 9016). Prices start at $20.
Other accessories include a glass panel for touchscreens and displays; this panel can be printed on the rear. Anti-slide feet are available for desktop use.
OKW can supply SMART-PANEL fully customized. Services include CNC machining, decor foils and EMC shielding. Digital printing and laser marking are available for adding legends, logos, barcodes, QR and DataMatrix codes; individual parts or enclosures can be printed or marked with consecutive numbering and/or text. OKW can
also install and assemble accessories in-house.
OKW Enclosures, Inc. 3000 Old Pond Road, Bridgeville, PA 15017, 412 220 9244, Fax: 412 220 9247, E-mail: [email protected], www.okwenclosures.com
You may also like:
Filed Under: TECHNOLOGIES + PRODUCTS, Cabinets • enclosures • control panels
