Humphrey Products Co., Kalamazoo, Mich., introduces the A10 and A15 Series pilot valves—miniature direct-acting solenoid valves that are perfect as a high value pneumatic interface, linking PLCs and air piloted pneumatic, or process control work valves.
Configured as compact 3-port sub-base mount, the A10 and A15 pilot valves feature low power consumption, excellent flow, and non-locking manual override. All valves are shipped CE registered, and RoHS / REACH compliant.
The A15 Series is 15 mm wide, produces 0.05 Cv flow, power consumption of only 2.5 W, and is available in standard DC voltages of 12 and 24 V. Valves are available normally closed or normally open (to 100 psi), electrical entry of lead wire or mini-DIN, including fluorocarbon seals, along with a non-locking override.
The A10 Series is similar but is only 10 mm wide, producing 0.01 Cv flow, power consumption of only 1 W, and is available in standard DC voltages of 12 and 24 V. The A10 is only available normally closed (to 100 psi) with a “plug in” style (axial or perpendicular) electrical entry position with a 1-in. lead wire included.
www.humphrey-products.com
Filed Under: Valves
