EXAIR’s Soft Grip super air scraper is a safety air gun designed to help remove the most stubborn debris found within industrial facilities. The patent-pending design uses a scraping blade to assist the powerful compressed airflow removal of debris.
This product is suitable for removal of caulk, gaskets, sealant, adhesives, tape, paint, stickers, labels, grease, and lubricant — as well as difficult-to-sweep metal chips, flakes, and discs. It will help keep machining tables, sub plate, and assembly stations clean and functional.
The corrosion-resistant scraper blade is attached to a 2 in. flat air nozzle and a ¾ in. extension to provide the strength and durability necessary for many of the toughest cleaning and housekeeping challenges.
Extensions for the Soft Grip super air scraper are available from 6 in. to 72 in. long to aid in cleaning tabletops and inside machines … and to reach the floor or other remote surfaces. Chip shields are also available through exair.com/58.
Filed Under: Filters (mechanical) for air + fans
