IIoT/sensor enclosures come in four new sizes
By Lee Teschler | October 6, 2021
Four new sizes are now available in the EASYTEC range of fast-mount flanged enclosures. The new larger sizes suit more complex applications that require extra installation volume – such as IT network technology and smart factory sensor equipment.
EASYTEC can be mounted quickly and easily on poles or flat surfaces in challenging industrial environments – either indoors or outdoors. Applications include okwIoT/IIoT, sensor systems, security and monitoring, stock control, environmental, medical and laboratory technology.
EASYTEC offers good stability. Its flat base has a curved recess for easy and secure pole mounting. Integrated mounting lugs feature apertures for cable ties and holes for panhead screws. The top is soft contoured for superior ergonomics.
Internal screw pillars in the top and base enable EASYTEC to accommodate two PCBs. Tamperproof stainless steel Torx assembly screws make the housings candidates for medical electronics.
EASYTEC is available in four plan sizes: original 80 and 100 – and now new 125 and 150. Each plan size is offered in two heights, giving a range of eight sizes from 3.97×1.96×0.86 in to 6.77×3.66×1.81 in. The enclosures are molded from tough and UV-stable ASA+PC-FR (UL 94 V-0) in off-white (RAL 9002) as standard.
Prices start at $19. Accessories include IP 65 seals, 2.5×6-mm self-tapping screws (PZ1 and Torx T8) and a Torx T8 screwdriver.
Customizing options include CNC machining, lacquering, printing/laser marking of legends and logos, RFI/EMI shielding, installation and assembly.
OKW Enclosures, Inc., 3000 Old Pond Road, Bridgeville, PA 15017, 412 220 9244, Fax: 412 220 9247, [email protected], www.okwenclosures.com
You may also like:
  • 9-11 truthers
    The WTC collapse after two decades
  • scilab
    The top ten free engineering math software packages
  • don't worry about EV fires
    Don’t worry about EV fires
  • electrocaloric cooling
    Keeping cool with capacitors
  • pie in the sky
    Sizing up renewable energy aspirations
Filed Under: TECHNOLOGIES + PRODUCTS, Cabinets • enclosures • control panels
Tagged With: okwenclosuresltd
okw
Control knobs cater to menu-driven electronics
metcase
Standard and customized 19-in rack cases, mini-racks, desktop and portable instrument enclosures
metcase
New 19-in enclosures meet latest DIN 41494, IEC 60297-3 standard
leadertech
EMI shielding kit includes fingerstock EMI gaskets in various shapes, sizes, and finishes
