EXAIR no-drip atomizing nozzles conserve liquid
By Lisa Eitel | October 14, 2019
EXAIR’s new 1/2 NPT No Drip Internal Mix Atomizing Spray Nozzles work like standard atomizing nozzles but have the added benefit of positively stopping liquid flow when compressed air is shut off. Internal Mix Atomizing Spray Nozzles mix liquid and air inside the nozzle and produce the finest atomization of liquids up to 300 centipoise. The patented No Drip design requires no additional air line to control the No Drip feature.
When spraying any type of liquid, post-spray liquid flow can cause big problems. Unwanted drips can ruin product function on sealing or mating surfaces and ruin the appearance of painted or coated finishes. In addition, excess liquid flow wastes precious resources such as expensive coatings, chemicals or water. No Drip Atomizing Nozzles are suitable where no post-spray drip is permissible. When the compressed air supply is shut off, the no drip nozzle positively seals off the flow of liquid eliminating the possibility of drips.
EXAIR’s 1/2 NPT No Drip Internal Mix Atomizing Nozzles come in four patterns: narrow angle round, wide angle round, flat fan and 360° hollow circular pattern. They are for pressure fed applications that don’t need independent air and liquid control.
The No Drip Atomizing Nozzles are fully adjustable to minimize air and liquid consumption and have interchangeable liquid and air caps. Flow ranges from 0.14 Gph to 303 Gph (0.5 Lph to 1147 Lph). They are also available in 1/8 NPT and 1/4 NPT, and are CE compliant and conflict mineral free. Prices start at $295.For more information from EXAIR Corp., visit www.exair.com/58/1_2ndint.htm.
You may also like:
  • Soft Grip air scraper from EXAIR with extension pipe
  • New hose-based conveyor option from EXAIR for materials up to…
  • 3/8-in. standard air wipe from EXAIR dries, cools, and cleans…
  • Multiple classified UL HazLoc cabinet coolers available
  • Dual Point Mini Cooler from EXAIR cools small parts and…
Filed Under: ALL INDUSTRY NEWS • PROFILES • COMMENTARIES, ALL INDUSTRIES, Factory automation, Industrial automation
Tagged With: exair
Lisa Eitel
Lisa Eitel has worked in the motion industry since 2001. Her areas of focus include motors, drives, motion control, power transmission, linear motion, and sensing and feedback technologies. She has a B.S. in Mechanical Engineering and is an inductee of Tau Beta Pi engineering honor society; a member of the Society of Women Engineers; and a judge for the FIRST Robotics Buckeye Regionals. Besides her motioncontroltips.com contributions, she also leads the production of the quarterly motion issues of Design World.
